RE: MaxCatV1-L Scratch Build
OK here is where I am at now on this build; I have got all the side stringer top and bottom, but not with out some problems, When you are ready to do this part of the build it is vary important to have the build attached to the building board and have all the frames and ribs straight, level, and in line, a lot depends on this part of the build. I made three attempts trying to bring the ribs into the nose, they would snap at rib #1. I am going away for a few days with my wife to spend some time together. I am not going to take it off the building board till I get back, so that all the epoxy can set up good. The next part of the build will be the tunnel sheeting. I think I will be using 1/16th inch ply for that.
Harold
