Thanks to some superb suggestions from members of this group, I've made some style changes to the automated response system to hopefully be more helpful.
Please don't hesitate to try it out!
For example, if you send an email with the word "narrowband" in the body of the email (please put test in the subject in case it does get through), the system will send you the same response it always has, except it is now broken into 10 parts and has a "table of contents" at the beginning to help make it clearer and easier to understand.
Additionally, I have modified the automated reply that comes when the auto system can't answer your question so that it also breaks down the plethera of information provided into easily understood segments and hopefully makes it more usable and more frequently read!
Curious what kinds of things the system can auto answer for you? These are just a few of the questions the system can answer, instantaneously, for you!
Is a 2PKA still legal?
What can you tell me about using Futaba gear for battle bots?
What parts are available for a 2PB?
How do I do a proper range check?
What receivers can I use with a 5NLP?
What is compatible with my PCM512 radio system?
What is DSC and is my radio compatible?
Can I reverse a servo?
Can I use 6V batteries with this equipment?
How do I properly care for NiMH batteries?
How do I do separate nosewheel steering on a v-tail?
what is a link mix?
Can I use the spectra module in my 8U?
What is AIL2 on the 8U and 9C?
How do i do twin aileron servos with a 5 channel receiver?
How do i use the rudder dual rate on a 6X Super?
Can my non-super be upgraded to a super?
Can I use a synth module with a 9Z non-S?
How can I use my air radio for a ground frequency model?
Does my radio have a back up battery?
How can I do servo slow?
How do I get a copy of a manual?
How do I buy a replacement switch for my 8U?
How do I replace a switch on the 9Z?
Explain CCPM. Can my radio do it?
Can I get parts for my old Futaba truck?
Can I use an R129DP with my radio?
Please compare the new 9C to the 8103. 9cvs8103.
How do i send my futaba item for service? where?
Can I register my Futaba item on line?
Please let me know what you see and what you think!!
Sincerely,
Mrs. AnnMarie Cross
Senior Manager, Proprietary Services and Support
Great Planes Model Distributors
[email protected]
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
