ORIGINAL: HandicappMan111
ORIGINAL: CrazyEh
Hey guys,
Question.. I'm going to pickup a micro DT next week.. What top 5 upgrades to help the truck run better, would you suggest?
Hey man you might want to grab a 3racing gearbox. they have them at TheToyz.com. They go like 15 something and if ur new to the site they give a 10% off ur first order. Reason I say get the gearbox is because the brass bushings in the tranny wear really easy! then all the shavings will go into ur diff and strip ur bevel gears. The tranny that 3racing offers has bearings that support the top shaft instead of the bushings. With the tranny box thou ull need to get a small washer or something to shim it. I used a small piece of fuel tubing i had laying around. just a heads up! cause after a while with a lipo ull notice a lot of play on ur spur.
sorry i ramble alot! haha
Thanks.. ill keep that in mind
