What is the maximum lipo for the trinity now? And how long of rolling?
There are a couple of companies that make LiPo's too fit the NOW , I use an Aero Nuts eXtreme series battery and use several other batteries from them all have worked very well .
[link=http://www.aero-nuts.com/product_info.php?cPath=32_57&products_id=453]Aero Nuts 11.1v 2200 mAh battery [/link]
I get about 30 minutes of running from mine ......
what wheel/tire combination can i go with for the Now?
[link=http://thetoyz.com/cart/thetoyz_details.lasso?id=8050&cat_name=]3 Racing Mini Inferno ST wheels [/link]
These will bolt right on and use the same hex size , you can also use MLST wheels/tires if you use the MLST wheel hexes .
Hey guys , I might have a solution too the weak diffs in the NOW , I mocked up a Mini Inferno 09 diff and its a direct fit !
The bearings are the same size and fit the NOW's diff cases like a glove , the Mini Inferno 09 diff pinion gear also fits the NOW's spur gear shaft and looks to be made out of stronger metal than the NOW diff pinion gear . And they are sealed diffs and tuneable with diff fluid !
Here is a parts list for anybody thats interested .....
[link=http://thetoyz.com/cart/thetoyz_details.lasso?id=9006&cat_name=MINI%20INFERNO%2009]Diff cases [/link]
[link=http://thetoyz.com/cart/thetoyz_details.lasso?id=8578&cat_name=MINI%20INFERNO%2009]Diff drive cups[/link]
[link=http://thetoyz.com/cart/thetoyz_details.lasso?id=8362&cat_name=MINI%20INFERNO%2009]Diff gears [/link]
[link=http://thetoyz.com/cart/thetoyz_details.lasso?id=8576&cat_name=MINI%20INFERNO%2009]Diff small parts[/link]
