delta wing incidence?
If you think about it you won't really be building in incindence but only adjusting thrust angles. Without the horizontal stab the main wing incindence will have nothing to do with how it will fly unless there is a thrust issue. I suggest building the wing straight (or with washout) and adjust thrust angles as needed.
