ORIGINAL: papajeff
GenesisFactor,
The inside of the canopy is about 2" X 6" but it is necessary to fit the battery, receiver and wires
inside and there is not much space left over. I don't get the part about not needing a speed controller
as, for sure, you need one. Maybe they are including it.
Hmmmm...its long enough, but not wide enough...i need 3"-4". I wonder if i can orient the items vertically instead of horizontally, if that will help my cause. I noticed some of you made hatches. I was hoping to push the smaller things through the fuselage and make a few cuts here and there (reinforcing with CF rods if i have to cut a rib). I just don't want to mount some of this stuff outside for obvious reasons.
