RE: Speed prop for OS 55AX?
MAS 11x7 scimitar 2 prop works well on my 7.8 lb F-16 with OS 55AX...just make sure you get the Dark Gray prop and not the black.
If you have a APC 11x6 weight it against the MAS 11x7 you will find it is a lot lighter as well.
cheers
