GWS P-51 Help
I had the same problem, so I simply drilled what I think is a 1.3mm or 1.5mm hole, right through the mount hole, and all the way to where I could feel the bit pressuring the foam on the top of the wing. They then went in fine. Don't worry about making the hole too "big", as your two screws per side will hold the gear on well.
