Update: I have sterted on one wing pannel, ihave all the ribs glued in, the spars are in place and the leading and trailing sub edges are glued in along with the wing tube. Next on the list is to glue the trailing edge sheeting in place and then i will add some block for my robart hinge points then edge glue all my sheeting for the leading edges.
Oh and to let you guys know I have friend at the field that lost his comp arf due to the reciever heating up and failing. If intersted take a look here.
http://www.rcuniverse.com/forum/m_76..._1/key_/tm.htm
So the new Futaba module that i bought and the 3 recievers that i purchased are not going into any of my airplanes. Darn glad it wasn't my new hybrid i would have been livid.
