Newbie questions about servo, rx, battery setup
Hi,
I have some basic questions about the different ways servos, receivers, and batteries can be connected. Thanks in advance for the help.
Q) When two servos are connected to the same channel on the receiver, do both servos respond identically to commands?
Q) Is it possible to hook up more than two servos to one channel?
Q) Is it possible to connect two batteries to a receiver to extend flight time?
Q) Lets say I have two seperate setups of two identical receivers each with its own identical battery. If I have two identical servos, one each attached to the same channel on each receiver, will both servos respond identically to a command?
Q) Could I wire the batteries in parallel and then wire the receivers in parallel so that each receiver gets the same amount of power?
Q) Is it possible to connect more than one servo to a gyro? Specifically, could I connect two servos to the GY601, or would this draw too much current?
Well, I quess that's it. Thanks a lot!
