RE: Northstar mods - Tell me what you think
I feel 6oz fiberglass is overkill and requires more finishing effort. Fiberglass on the tip floats is also overkill.
I used K&B Medium (2oz.) fiberglass for the pylon area and forward bottom of the hull step. On the rear of the hull step I used K&B 0.075oz.
If you plan to use a 0.46 engine and expect it to perform, your overall weight should be under 6.75 lbs.
