RE: Difference between 15c and 20c lipo worth it?
You need to increase your mAh to get more run time. Changing C rating increases or reduces available power. You should purchase a battery based the amp draw requirement of the motor, if you get one that can't produce the necessary amps it will destroy the battery.
