ORIGINAL: GreenAcre
Servo Extensions?? What are you guys using? I have 3 y-leads for the rudders,ailerons,flaps. (I am using one servo for the elevater). I figure 4 12" for the ailerons/flaps 2 36" for the rudders and one 48" for the elevater. And some 6" extensions coming from the Rx. to connect everything.
Thanks!
GreenAcre, how did those lengths work out for you ? Were they accurate ? Reason I ask is that I haven't purchased any yet, and I'll probably be doing something similar. I'm fortunate enough to have a full size van, and hope to be able to leave it all together permanently. I'm assuming that you didn't use a connector between the wing and the boom. Is this correct ?
... zak
