RE: Prince 25" Mono
Hello All-> FHH!
I got my boat in tonight and started to monkey around with it. I specifically started to look into the vibration deal you mentioned.
I found the problem which was very obvious.
Heres my measurements:
propshaft: 4mm/.156"
Prop: 4.83mm/.188"
Drive Dog: 4.11mm/.164"
The vibration has to be due to the wrong prop for the shaft.
Also the motor is 28X30 with a 16mm/.620" bolt circle diameter.
Im fairly impressed with the quality construction at this point. Im going to get the servo in tonight.
More to come!
