RE: What do you think of FORMOST 150 ?
Hi Rich,
I have just finished my Formost 150 and should be test flying next weekend. I'm using a P-80, only because I have it lying around. I had to raise the entire turbine 3/16th" plus raise the front 1/8" just to clear the formers under the turbine. Did you get your trailing link struts from Digitech, and if so, what number struts did you order? Did you use Robart 630 retracts? Did you have to modify them at all? Did you have to modify the wheel wells in the center wing section? I have my ailerons cut to make inboard section flaps. Should there be anything I need to look for, such as high angle of rotation or any roll to left or right?
Larry
