RE: Using a PowerExpander Pro with a JR 1221 Rx
Hi Bobby,
I guess I am not sure what is not working for you. Have you hooked a servo directly to the receiver on the channels that are not working to verify the transmitter is programmed correctly? The transmitter may require setup to assign the channels you are using, you did not say if you did that or went with the default transmitter programming. Can you please give me more explanation on what you are having problem with? Is it that the channels on the receiver work when hooked up directly but now when hooked through the PowerExpander? Thanks,
