Airtronics Radiant Transmitter - HELP
I have the Airtronics Quasar which is the Radiant. If I remember correctly, move the cursor to the EPA position to adjust end point values (hold the stick in the direction of the end point you are adjusting). For servo center adjustments, I think there is a position called sub T. (for sub trim). Move the cursor to that position and you can adjust the center point of each channel. Hope this helps.
