RE: Stihl 65cc 4-mix on 30% Edge
J, glad you got her running. I think the WT (butterfly) carbs pump more fuel than the WYK. My thinking is that a chain saw would need more fuel than a weed wacker (but I can't prove it) and it seems all the chain saws use a WT. The B&S needs more fuel than air also. I wanted to make sure I could run pretty rich because you know it's probably going to get lean in the air. Just my 2 cents worth.
