RCU Forums - View Single Post - RCGF Engines
Thread: RCGF Engines
Old 08-14-2008, 01:37 PM
mmattockx
Default RE: RCGF Engines
SunShyne,
From Henry's site:
Displacement (cc) 26cc
Bore x Stroke (mm) 1.33"x1.12" (34mmx28.6mm)
Carburetor Walbro
Ignition DC-CDI (electronic ignition system)
Power supply 4.8-6V
Weight - with ignition and muffler 39.6 ounces (1122g)
Weight - without ignition & muffler 34.4 ounces (975g)
Maximum Output 2.6hp/1.85KW
Speed range 1500-8000rpm
Gas/Oil Mix 25-40:1 (90 octane gasoline)
Propeller 18*8 7100 rpm
I added the bolding. Henry told me tested the 45cc with Xoar props, so I expect that is what the 26 got as well. It is not as strong as a good glow engine of the same size, but it is doing decent numbers.
Plasticman, you will have to buy one and tell us how it works out with the pipe. How's that other 26 and pipe working in your big Fusion?
Mark
