Futaba 9C, Mixing questions...
Hi, David! first quesiton, do you have to use 6/7? these are curve mixes, meant to be for adjustment of diff amounts at different throws. its much easier to use 1-5 if you can.
assuming you cannot.
1) MASTER = rudder
SLAVE = elevator
points1 through 5 setting = 7% (might find need +7% on one side, -7% on the other, some models do)
switch (doesnt matter)
position NULL
link OFF (unless you have any elevator-xxx mixes that need to be obeyed, like for 2 elevator servos not using ailevator)
trim OFF ( you dont want the elevator compensating when you just give rudder trim)
Let me know if this helps!
