RE: Flight Trimming Issue:
Did you check the tail incidence per the instructions or via the details here in the forums? There's a known problem with the tail incidence on the Vipers.
Other than that, it sounds like you've got too much down thrust. On a racer like this it should have zero right or down thrust. The tail should also be set with zero incidence.
Good luck,
Chris
