RE: Need help asap for firewall doweling/re-enforcement
Well I fit the dowels and sanded them down on the front. I then slapped a coat of 30min epoxy to the front. The rear of the dowels is what looks crappy. There are some chunks of the ply missing. Not horrible though. Do you think I should fit the blind nuts and engine then put a layer of 1.5oz glass to the inside over the blind nuts? I could prob drill small holes through the blind nut and then the fiberglass so the bolt easily passes through.
