ORIGINAL: tIANci
I got a China made 56mm motor that is about 2,000KV ... will try it and see if not good then I shall go with the HET as recommended! Thanks!
Hi tIANci et al.,
Have you had a chance to check your China made motor? If so, how does it work?
I have a couple more questions if anyone has some thoughts on these?
1) Does anyone know if the "servoless" retract will fit and work in this plane? I've seen it sold at several places (
http://www.ejf.com/index.php?main_pa...roducts_id=525). Watching the video of the flyfly air system retracts makes it appear cumbersome. I would prefer not having to bring a bicycle pump to the field, as well.
2) It sounds like the HET Typhoon 600-32 will work w/ either 5s or 6s batteries. What would be the difference? Would the 6s provide stronger performance... is that the only difference?
Thanks so much to Extreme RC for all of his work and information on this plane. It really looks like a great set-up. I hope to build one out this fall.
Thanks for anyone's comments, thoughts, or updates on their experience,
Charlie
