Thats the servo but they had it listed at 1271 oz/in at 8.4V
I wouldn't put 12 volts on it for the power, just the speed b/c it moves ungodly slow at 6 volts and still pretty slow at 8.4
here is what was on the website I found on
http://www.tokyo-hobbies.com/tonegawa.html
Operating Voltage:
Vmin-max: Dedicated 4.8 - 12.0 VDC, not shared w/receiver
Recommended Operating Voltage:
Vin: 6.0 - 8.4 VDC
Starting Torque:
Ms 65.33 Kg/cm (907 oz/in) @ 6.0VDC
...91.50 Kg/cm (1271 oz/in) @ 8.4 VDC
Speed:
0.29 sec/60 deg. at 6v, 0.21 sec/60 deg. at 8.4V
Weight:
280 gr.(10 oz)
Size:
Length: 100mm(3.94") including mounting flange
..........75mm(2.95") body only
Width: 44mm(1.73")
Height: 93mm(3.66") w/ output arm installed
.........79mm(3.10") body only
