JR 662 & Delta/Elevon set-up help please.
Just to clarify:
* go to system menu
* enable DLT wing mode
* plug servos to Elv and Ail (as per V-tail instructions, that's the only wing type that they tell you how to plug the servos).
* cycle power switch
* go to servo reversing menu
* try out different Elv/Ail Norm/Rev untill you get the correct stick movement; ie:
* pull stick both elevons move up, push stick both down
* right stick R elevon up, L down; left stick L elevon up R down
You have to adjust the Norm/Rev as servo placement is different for each a/c (ie, servo is on top or below, facing forward or backwards, etc)
