Hi phillybaby
This was my first flight with new engine an pipe, so never had a previous problem.
I didn't catch exactly what you meant about the RX loop.
If that is also a problem, do a see it with a flyby with the wing tip pointed directly at my TX?
regards
Todd
Originally posted by phillybaby
yep, a loose header give metal to metal vibration, bingo, interference. was this the first flight? did it do it before?
if you didn't have the loose header i'd be after your loop tho, interference when its edge on to you is the sign
