ORIGINAL: tralalala
Gerald,
[X(] Is that a Sieg X1 mill? That's quite good work you're doing with such a small mill. Did you turn the diffuser on a Sieg lathe too?
Thanks, the lath is a Black&Red X1, must the the same as you mentioned and the lathe is a local configured item, don't know where it originates from. See picture for my home shop where I make all my turbine engines and retractable gears on like F16 scale gear and some copied Jet A1 struts for my latest jet. Is time consuming but for sure more fun and cheaper than buying the parts.....
rgds,
Gerald
