Old 05-28-2003, 03:39 AM
MO_Radio_Tech
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JR rx, heard bad things
When you solder the wires in a servo, also glue them down with Contact Cement. This prevents wires from coming loose from vibration fatigue.
If you open most servos, you will see this yellowish rubbery glue. If you sent the servos in for repair, techs would add more glue for this very reason.
You could be on to something here, hope you can track this Gremlin down.
If the receiver was bad from the factory, the Aileron channel would have probably been dead from day one, due to static damaged IC or cracked resistor/trace on aileron.
MO_Radio_Tech is offline
