ORIGINAL: MOTORMAN37
ORIGINAL: russm
have to agree w/ rh above. right now a 13-6 apc. no digital camera for pics. like the toni and minnow, the tank fits in the first former very tight. not a good thing. i take a dremal and ream out the former about an 1/8", then wrap the tank in some thin foam and slide it in makeing sure the foam stays in place. then i pack the balance of the cavity with foam. have had problems w/ bubbles in the past. this has cured the problem for me.
You sure you have a YS 1.10, because a 13-6 is way way way to small.
Quote from "russm": "14-6, my mistake. no shoehorning involved. anything smaller is not worth the effort. and yes, it is a 110"
Quote directly from YS 110S manual: Select a good quality propeller that will turn in the 8,000 to
11,000rpm range. We recommend sizes 14x11-12, 15x10-11.................................
Have fun, but please be safe with your props around people. Whether or not you are gonna prop your engines to your advantage.
