ORIGINAL: mk1spitfire
Ok, cheers
Is there a way of saving the graph to file on wavescope?
Running a video an panning the plane might not give you a true speed???
I use Paint Shop Pro to capture the screen and save as a jpg file. While the program is open and active you can also use alt/print screen to copy it to the clip board and then paste to Microsoft Word ctrl/v or other graphic word processor.
Panning with the camera is not a problem. The microphone is one place and the plane should fly in a straight line in front of the camera. Two to four seconds is all you need.
Edit - Change Print Shop Pro to Paint Shop Pro.
