ORIGINAL: JEREMYB
Which is the best mount to use for the OS AX 55? I would like to use one that uses the back plate design.. Any links on where to get one? thanks.
JEREMY BONNOUGH
if you can get onto Great planes, the Viper has a very nice alloy engine back plate mount that should be quite cheap . the 46 and 55 have the same crankcase so the normal 46 mount will fit .
