RE: Rossi Quickie 40 - Needs a plane
Hi!
What is used in F3D pylon is just a wire with a loop around the fuel line.....the wire is connected to the side rudder servo and when you give full left rudder (after a heat) the fuel line is crimped so that the fuel is shut off.
