RE: T-tail Quickie
The horizontal on the Thunderquickie is: Span 19 in, cord at center 5.5 in, cord at tips 3.75 in. the plan form is a double taper. Much more taper on the leading edge than on the trailing. The vertical is 3.5 high from the top of the fuselage, cord is 7.5 at the fuselage and 3.5 at the top. Again double taper with only a little on the trailing edge. hope this helps.
denis
