RE: Atlanta Fuselage Splash..
Thought i'd give this a bump and ask a few questions.
Hey Chuck. I was trying to figure out what resin material you used throught-out your splash process.
Did you use Polyester resin for the splash and and master mold?
or Was it polyester for the splash and epoxy for the master?
I guess what I am trying get at is are you switching between the the two resins as you build your tooling mold to get to the final fuse?
eg as in steps
1. polyester = splash
2. poltester = master
3. epoxy = tooling mold
4. epoxy = fuse
