Hello, all of you. I took a vacation a little. I'm sorry.As for my specifications, as for the motor as for HACKER-B50 ESC Jeti-Spin FAN is Air-power AP900. Battery is the whole thought .It is thrust 2kg on an FAN simple substance test at an acquaintance. Is two deployment in this; body weight (including battery) 4 kilos a little.A clear canopy and a cockpit are own work. And, as for Gear, this chose Air-Power.
Then my expectation does not open and close the main wing. I like the figure which merely widened a feather of merely TOMCAT. I do not feel the figure of the landing. Therefore, LED incorporates it and is already considered to be the main wing and a vertical tail.
