Old 11-24-2008, 10:55 AM
  #32
Craig B.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Composite ARF Mig29
Hi Matt,
Thanks mate. No, I have not cut out the nose doors yet....she has been on ice since the birth of my last daughter[]. to remove the pivot tubes was very easy infact. Just get yourself a small screw driver with say a 3mm wide blade. Sharpen the end to a blade and working from the outside, chisel out the tube. It will fracture into longitudinal slithers and break out really easily. I should know ....I did it twice. It is alarming how easily it fractures. This prompted me to consider putting a wrap of carbon fiber roving circumferentially around the inboard end of the tube. I am definitely going to do this once I machine some fittings for the inboard end of the pivot rods as suggested by Peter Agnew at Intairco....I will try to find some pics of them.
I just got some new tubes from comp arf and installed them. I am not overly impressed with the fit of the old or new tubes and will probably machine up some ali pivot tubes to fit neatly.
i got some high strength aluminium from Peter for the job.
Can you post some pics of yours? Did you reinforce the landing gear plates?
Hi Van,
Yeah I got some of Peter's doors also and his wheels and brakes.....they are a little smaller to fit through the door opening, a good thing in my opinion. Yours is looking very good.
Regards,
Craig.
Craig B. is online now
