RCU Forums - View Single Post - Aeolian 910KV Motor
Old 11-24-2008, 01:30 PM
jstanton
My Feedback: (14)
jstanton's Avatar
Default RE: Aeolian 910KV Motor
I just got my order in last Friday of 2 - 2350mah 14.8 lipo's from HC. I went home with them and tested them Saturday on my Aeolian 910kv motor. I have a 60amp esc on it know so I fired it up using the APC 11x7 prop I already had on the ME-109. It put out 585watts of power. [:@] I only had it here for about 5 seconds if that long. Believing this is really a Turnigy SK-3636 motor rated at 470watts I changed the prop to a APC 9x7.5. I fired the Aeolian 910kv up again and this time I hit 470watts right on the noise.
I will keep this configuration on my Modeltech ME-109 and with the bigger battery I weighed the plane again and it is still under 3lbs(2lbs 14oz). I will have 150watts per lb on the plane and I hope to test fly it this Wednesday. I'll let you all know how it went.
