Help with Left / Right Stick Swap
I am left handed and looking to reverse the two sicks on my Futaba 6VA. I simply want to swap the left and right units. I have partially disassembled the Transmitter and I am now looking for the best way to accopmplish this task. It appears that the left and right units are not interchangeable and therefore cannot be swapped. My next thought was to simply swap the wires between the two units, then swap the spring and the ratchet from the opposite units. Please advise on the best way to do this, if this is recommended procedure. Do I need to cut and re-solder or can I use the connectors? Anything that I need to watch out for? Any worries of re-calibration?
Thanks in advance for your assistance.
