RE: Sheeting Foam wings
what i can,t understand is the use of excess weight just to glue 2 surfaces together, surely if too much weight is applied to the soft foam and the soft balsa [ whats going to give ] also where is the glue going to go [ squeezed out ] . when you look at foam there is no penetration of glues to soak into the cells, also goes with balsa wood.
