RCU Forums - View Single Post - Learjet .40 Build
Thread
Learjet .40 Build
12-02-2008, 08:04 PM
27
vupilot
1 Post
RE: Learjet .40 Build
Spent the evening installing the tip tank mounts and sheeting over them. I sheeted the top then the bottom before I realized that there is also a bottom mount so I had to carefully remove the bottom tip sheeting to install it. The instructions dont say to install the bottom until 3 steps later...dummy, always read sevral steps ahead of the one you are working on. I should know better.
Also installed the main landing gear mouning blocks and reinforcement. Drilled the hole required for fixed gear legs and test fit.
Reply
Like
vupilot
View Public Profile
Send a private message to vupilot
Find More Posts by vupilot
View iTrader Profile
