RE: Learjet .40 Build
I thought of using it for a pattern as well. I was able to get them out and flipped without breaking them. I wish I had just left them alone which was my original plan when i noticed them installed wrong. Since you noticed it though I thought I would fix it right but the wing is symetrical so it wouldnt have made any difference in really.
I am installing the torque tubes, ailerons etc right now, still going to use a single aileron servo and the torque tubes simply to keep the look of the wing more scale. Since I am going with fixed gear I may even make fixed gear doors so it looks more scale when parked on the ground. That will come after I have had several flights on it.
