Old 12-07-2008, 08:29 PM
  #42
Ro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Composite ARF Mig29
Hi Matt,
I took the struts to a tig aluminum welder and had him just do a simple spot weld. His job was pretty nasty so I grinded away the excess and put jb-weld over the seems and will sand it away so that it looks nice and
clean. Still have alot of cleanup to do on that nose leg also!
I have a new set of alloy wheels/breaks from www.Intairco.net that will fix my clearance problems. The axel hub will be retained with a set screw and locktight after the tow-in angle has been set. Its the same stuff
used to secure the caps on your rams. I had a leaking ram and all I had to do to fix it is heat up the locktight glue on the cap threads and off it came.
Ro is offline
