RE: ESKY LAMA 4 THREAD
I forgot to mention that it is alot easier to mod the CX because the Servos face parallel with the heli and have a longer stock servo horn than the Lama does so you can move the linkage to the outer most hole for much faster movement.
The lama is the opposite. You have to buy a longer servo horn since the stock one was cut off so it doesn't hit the body, when you install the longer servo horn on the Lama you have to trim the body so it doesn't hit. Then it will fly faster.
