RE: Learning to use a hi-start
I am putting together a home made hi-start using solid (not tubing) 1/4 inch diameter rubber. It's known locally as 6.4 mm barrier cord, and works very wellin fact I've just flown from a borrowed hi-start made from this. Trouble is, the supplier made up my order of 60 metres (enough for two hi-starts) as three bundles of 20 metres each. To make a 30 metre length,which is what I want, I will need to make a join.
How best to do this without knots or bulky joining rings ? Any advice gratefully received.
