RE: 35% IMAC Setup???
Hey Todd
You're going to get lots of opionions here. I just put a 35% extra together so I'll give you my setup. I went with the A123's and I gotta tell you, I think they're awesome! You get PLENTY of amperage from them, plus you have no need for regulators or a power expander. Just my opionion, but the more things you add, the more that can fail, especially electronics. I use 2 2300 packs for the reciever going through 2 smart fly switches, just for redundancy. I have the cellpro charger which tells you how many mah you have used when you recharge. Typically I use right around 200 mah or less per flight, which is not much. You can get a lot of flying in on one charge, plus it only take 10 or 15 minutes to charge.
What reciever and which Hitecs are you planning on useing?
