how many tanks of fuel did it use untill it lost compression ? . if your looking for insane power on a topend only i would use a esp raceported head with a stuffed crank , and zero engine drag seals in brass . if you want to go for the real deal of insane power i would drop in a trevor simpson induction crankcase with a stuffed crank and a $19 35mm cy head from DDM then raceport that head , if you do that the insane amount of power will put a big smile on your face lol
