RE: AquaCraft Alligator RTR
I was only changing the settings on the HS needle. When the prop is spun by my spin starter motor, fuel/air (mist) comes out of the exhaust. I've seen when an engine floods then you can drain the fuel out of the exhaust or it drips after trying to start out of the exhaust, but this engine mists fuel out of the exhaust while spinning. I tried to lean the mix out to see if flooding was the problemstill mist from exhaustno fire. The piston won't compress fuel /air. The engine wouldn't even sputternothing. This engine is bad. If it was a used engine I'd say sleeve, but this engine is new. Back to Tower it goes!!!
