RE: AquaCraft Alligator RTR
The HS needle. Don't touch the LS needle what ever you do; you might never get it started then. Turn the HS needle in all the way then turn it out 2.5 turns. If no start, pull plug, pinch fuel line and then spin engine , put a rag over the plug hole so fuel doesn't spray all over you, then turn in 1/2 turn to 2 turns and try again. The Tower tech lady said to put mine at 1.5 turns out and then try but it still didn't run until I was at 1 and 1/8 turn out. After you go below 1.5 turns only turn it in 1/8 turn until it stay s running. That's how I got mine to run now I have to address the fuel leaking between head and case. Mr CajunGator said to pull head and sand sleeve in an earlier post to this thread. i'll try that next before shipping back to Tower.
