ok chaps uploaded on you tube is todays run with the shell on it and i must say that thing moves quite well, although the brake was binding a bit (had no tools with me to set it up) and i became apparent that the steering servos where reciving interfearence from the motor (will have look at that but more like a dodgy reciver connection)
yep it needs the better steering but i will wait till i kill the servos first only 25euros a peice not much (strange things use a y type cable and take power direct from the bat)
oh its going on a diat too, lots of things i left on that can be removed. also goin to simplifie the front "suspenders" and move the brackt down so the spring receives more commpression from the swing arm, this should absorb more shock!!
this might be good ... the video file!!
http://www.youtube.com/watch?v=rnBLJDJlid4
