RE: Great Planes Escapade .40 ARF
Seahawk,
I did spend quite a bit of time trying to get the tail assembly bolts to line up with the holes in the bottom of the fuse. My solution was to turn the fuse upside down, then bend the bolts slightly to align with the holes. When mounting the tail assembly you have to make sure the front and rear projections fall into the slots. After a little wiggling it will match the holes and seat properly. Bob T.
